Luke_Healey
Last night I jumpered my car horn, which works just dandy... So I busted out my wiring diagram and saw that the two horn wires lead only to the unswitched fuse and the horn push button on the steering wheel.
I'm curious how the steering wheel button works. I took the cover off of the turn signal controls to douse them in electrical contact cleaner last night. I see how there is a brass ring on the column with a contact that is in the purple wiring line for the horn. Then there is obviously the spring loaded button inside the column. I'm getting nothing there, but I didn't want to pry out that spring loaded center piece. I guess Victoria British refers to this spring loaded button as the 'horn brush'
When troubleshooting the horn circuit, what should I look for? Grounding out the horn wire, I get power to the horn (good!) But I'm curious how the horn wire inside the steering column works. Is there insulation on that brass ring? I would think the column itself would be grounded. Does the horn brush have a wire hooked to the back of it? And can I safely pull it up out of the steering column without ruining the spring in it?
Thanks for any help.. I wanted to ask first so as not to destroy anything /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Hi Guest!
