SOLD!! 1964 AH Sprite MKII
George Zeck
Hello All:
We've decided to downsize and it's time to sell our Sprite that has been in the family since the early 80's. A significant restoration was completed from 2003 - 2006 which include:
  • Exterior Paint
  • Interior / Seats / Panels / Carpeting / etc.
  • Dashboard
  • New Windshield / Seals
  • Buffed out Windshield Columns
  • Rims sanded & refinished
  • Front Bumper (Rear is OK, not quite bad enough to replace).
  • Engine Swap & Re-build (1275)
  • Transmission re-build (Manual & Non-synchronized)
  • Clutch (Reg & Slave)
  • Weber 32/36 carburetor
  • Differential (better ratio)
  • High Flow Radiator & Oil Cooler
  • Water Pump
  • Halogen Headlamps (front only)
  • LED Brake Lights (Rear)
  • Conversion to Alternator (negative ground)
  • Upgraded to Modern Fuses
  • New Fuse Panel / Relays
  • Speedo / Tach / Volt
  • Starter / Ignition / Pertronix / Distributor / Coil / Wires / Plugs
  • Radio with CD / Headphone connection for iPhone, etc.
  • XM dock & rear speakers
  • Wind Buffer (see pictures) – you can drive and talk with someone &/or wear a hat safely.
  • Front Suspension – Shocks
  • Rear Suspension – Dampeners
  • Brakes, poly bushings, bearings, master cylinder (single)
  • Front Discs / Rear Shoes
  • Exhaust & Manifold
  • Wood Steering Wheel
  • OOOGGA Horn
  • Chassis ID: HAN-7L-36045
  • Body ID: 028144
  • Engine ID: 12C/Da-H-22863
Every ‘system’ has been touched on this car. We’ve taken the car for extensive trips out of state and she runs great. I’m selling as I have four cars and three spaces. This typically gets left behind due to family size. I have a few various parts that will be included (SU Carbs, Orig. Diff, Manuals, and whatever I can find). It has an Ohio title and in my name.
I’m sure I’m forgetting a lot but that is in reference to items I’ve restored / replaced, etc. and not listed. I’d be happy to answer any questions. You can see the build costs are much greater than what I am asking. I built it for me and reliability. These pictures were all taken 7/21 2023. It's showing normal signs of a 15+ year restoration; a few chip marks, a paint bubble that not getting worse / better. It's incredibly reliable. I can take any pictures you’d like / answer questions. It’s a lot of fun! Thanks.
Asking $6,500 / Offer. Less than Hagerty's Online Valuation Tool. Please contact me via PM or at 440-454-2224.
Thank you
George
Cleveland, Ohio
(aka Spritey1964)
