1960 TR3 engine serial number
Pool Dad
A little help please. I once saw a thread here on how to identify the engine blocks serial number. Want to ensure it is a true TR3 engine. The block is stamped with:
ICF1960E. I do know the E stands for engine. I also have the commission plate as well. Any assistance would be a great help
Andrew Mace
Likely that first character is "T" rather than "I," so the engine number is TCF1960E, making it (as built) a 2.2L TR-3B engine. If your commission number also begins with TCF, then you do in fact have a "later" TR3B (actually built in the 1962 calendar year and often ultimately titled as 1963 models).
charleyf
Probably a 1958 motor
The block is NOT likely a 1958 motor. I agree with Andy that the block is likely ( if the TCF is correct) from a 1962 TR3B. One additional identifying point is to locate a number on the cylinder head located on the passenger side near the front . That number should be about six digits and have 55----. Early heads did not have any numbers there that I know of.
But as these engines have interchangeable parts you could still have an early head on the later block.
Oh, if these cars could talk!!!
Charley
Pool Dad
Pool Dad
Thank you Charley. Yes if only they could.
I’m 99 percent sure it’s not the original engine to the car. Was hoping it was but too many questions. Now it does have the overdrive and i am just starting to look into whether the 1960 models came with that option.
Andrew Mace
There's no doubt in my mind that TCF1960E is not the original engine. As to overdrive, that was available as an option from the very first TR2s; note the the earliest cars had OD only on top gear. Your commission number ending in "LO" establishes for certain that the car was equipped with overdrive when first built.
charleyf
Yes they did. But with the different engine block , you may also have a different transmission. That may be good for you. The trannyi that came behind that TR3B engine block had synchromesh between first and second gears. The early transmission did not.
Charley
Pool Dad
Pool Dad
Thank you Andrew. My conclusion as well.
Given that and it’s sat for 18 years in a container and everything is seized up and has three coats of paint but little rust. It’s complete with hardtop as well and wire rims. I ask this to you and anyone else who would like to reply. What would think it’s value? I’ve restored several Triumphs and MG’s so I’m not a novice by any means. My feel is to just getting it running, rolling and stopping is going to be 5 to 8 k.
thoughts for all appreciated
DavidApp
Does everything is seized up include the engine?
5 to 8K would probable be a good top number for just getting it running and rolling. The clutch may have bonded to the flywheel and all the brake and clutch rubbers will need changing. If the engine is OK the number would possible be lower but these cars can become an open pit.
The TR3 that you showed in the container looked to be in good shape.
David
Pool Dad
Pool Dad
Thanks David. I know on their ability to suck your wallet dry. If all the serial numbers matched it would be easy decision. Never rebuilt a bastardized car before. All of mine have been original. But lover the challenge
charleyf
I would not call your car with a different engine block a bastardized car. It has a TR3 engine I believe that gets you 90+% of the way to a great car. To me bastardized would be a V8 engine .
I have two what people refer to as beautiful TR4s. Yet neither of them has the original engine or transmission. Both cars do have the equivalent engine and are restored to near stock condition.
I believe we now call it personalized.
Charley
Pool Dad
Pool Dad
Not my car yet. But trying to justify the 20 plus to make it perfect. Bastardized was a bad choice of words
Pool Dad
Pool Dad
Thank you all for your help with my serial number questions. Tournament out it is not the original engine or transmission to the car. Bummer. Plus another snag the owner doesn’t have the title. Here in the state of Washington it’s a long process to get a replacement. Won’t do a salvage title. Oh well I’ll keep looking and sell off some spitfire parts and make some room in the garage.
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
pbraun TR2/3/3A 1960 TR3 photos Triumph 17
Tinkerman TR2/3/3A Bonnet stay rod 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A 1960 tr3 a to gasket or not to gasket Triumph 35
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A hood stick color? Triumph 2
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
Tinkerman TR2/3/3A Wind scereen support bracket tr3 a 1960 Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
R TR2/3/3A 1960 TR3 Restoration Triumph 8
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Tinkerman TR2/3/3A 1960 TR3 Post 60000 elec equipment Triumph 12
boxofparts TR2/3/3A Dads TR3 way back in 1960 Triumph 16
J TR2/3/3A New Member 1960 TR3 Triumph 11
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
