apbos
Thank-you! More to follow. The A-arms are having new bushings put in. I'm working on my carbs this weekend.
tony barnhill said:Beautiful - but is that the correct color for the top bows?
Used the same paint as the rims. I know they are supposed to be grey, but I had some left over paint. I might leave them that way. I'll only need one color for touch-ups. They are not original B/E bows, they are split in the middle. They came with the car.
& how'd you do the manifolds?
Dupicolor High Heat Engine Ceramic paint
& what color did you use for your fan?
Rustoleum gloss yellow. The black is semi gloss more over etching primer and high solids primer where there was some pitting. On the suspension pieces and more exposed pieces I used POR 15 with a top coat of semigloss while the POR 15 was setting up.
Paul
