Flatlander
I recently got started a Spitfire 1500 that I had purchased. It idles smoothly but there is a noise originating in the lower front of the engine. The noise is a heavy "clunk" that is intermittant. It might manifest itself every 3-4 seconds or more but is not regular or predictable. Immediately after reving the engine from idle there is a single "clunk" then it goes away. (At higher rpms it might still be there but at a greatly reduced level such that it is difficult to discern.) The noise seems to be coming from the timing chain cover as opposed to the front of the engine block. Again the confusing thing is the "heaviness" of the noise making you think it is associated with the crank but as I said it is very intermittant. Any ideas?
Thanks,
Gary
Thanks,
Gary
Hi Guest!
or you'll be changing the radiator realsoonnow.
