I think the sleeves you guys are seeing in catalogues are for installing in an engine that has too much bore wear. The block has to be overbored and the sleeve pressed in. The standard engine does not have them. The top of the block around the cylinders is recessed and may be what some are calling sleeves. I've read that a 1500 engine can be overbored .060. I think that is the same as a 0.020 over TR-6 piston, which is supposed to be lighter and the cats PJs.
The 1500 does not use cam bearings, but as some have said, can be installed. The block ahs to be bored and its not cehap. John Kipping (well known Triumph expert) says the bearings aren't all that critical unless you are racing. He also says you can install Pinto valve seals, but you can't then use double valve springs. Leave the inner spring off.
Not only do these engines drop thrust washers, they eat big end bearings too.
