aeronca65t
Honestly, I'm not sure (and I don't have anything around here to measure).
I think you could put the original straight cover (and pickup) on the new pump (if you still have the original pump).
By the way, when you re-assemble the pump, you should check the clearance between the side of the rotors and the cover...basically, the closer, the better. I lapped my pump-body and cover down on a plate until it had only about 0.001" clearance. Just did that the other day, in fact.
