1500 Midget; sticking choke
Steve P.
I'm discovering the later Midgets have some interesting
quirks the earlier ones did not.
The latest is the automatic (sic) choke on the Stromberg
carb. About the only way to get the engine started is
with starter fluid. Within a few seconds of getting it
running, the choke engages. High RPM's for a short
period, then it settles down and runs GREAT. Nice
steady idle and plenty of power. It seems like the choke
works, but is sticking in the off position. Have tried
tapping gently (and not so gently) on the side of the
choke housing, but that doesn't help.
Planning to dig into this in a few days. Can anyone offer
any tips or suggestions? TIA
Steve
p.s.-I'd love to add on a manual choke or dump the
Stromberg and put on an SU (which I have), but I'm in
the state of Kalifornia, and would never pass smog with
mods
Wow, I was going to suggest John Twist but I had no idea there were youtube videos.
It all makes so much more sense now!
The John Twist article is good, I've made use of some of the info. Sometimes I have to hold the accelerator down slightly to help it if it's being stubborn. When mine was giving me grief I found the choke needle was gunked up and the cam pivot needed a drop of oil. Unless the CA inspectors are intimately familiar with the Z-S you could probably get the manual choke kit.
Check the choke pull-off piston too, if that's gunked up it doesn't work well.
I just went through the CA test only process. I could have had a banana taped to the intake manifold and the test guy would not have noticed.
As long as it passes the tail pipe test you should be ok with just about any carb.
