G
I received my "new" 76 MG Midget last night. It looks great and everthing seems exactly as I thought it would be. I do have a question or two. I have never owned a car with a hydraulic clutch (my old Fords had mechanical linkage & springs). Is there any adjustment for this system? The clutch engages just as the clutch pedal comes off the floor. Is this correct? Also, the gears grind a little when down shifting from 4th to 3rd. If I double clutch I can usually down shift without the grinding. Is this a clutch issue (adjusted incorrectly or worn) or is this a transmission issue (syncronizers)? Any help provided will be appreciated. Thanks.
