mikecyc72usa
This is what I've heard, but it doesn't answer one question: Were the pushrods the same length as on other years? Or were there 1976 specific pushrods?
There are numerous heads that came on the 1300 and 1500 engines, and they are all interchangeable, but that doesn't mean you should interchange willy nilly or you can end up with too high or too low compression or trade down to smaller valves. If you are keeping your basically stock North American market engine setup, then no point in looking for another head--just tidy up the one you have. But if you want to do a little more and will be improving the flow into and out of the head (better carbs and intake manifold, and a decent exhaust), then finding a "big intake valve" head from a world market late 1300 engine will yield 8.9:1 or so on a 1500 with dished pistons--an upgrade that'll require no messing with the bottom end to change to flat-top pistons. Shave about 0.040" off this same head, and voila--approx. 9.5:1 compression, which will do fine on ordinary premium pump gas and a reasonable ignition map and not knock. There are a few other "big intake valve" heads to choose from, but for most you'll also need to switch to flat top pistons to help raise the compression enough to help. But as has been said, without some other mods, this upgrade would yield little improvement.
The combustion chamber volumes of your 75 and 78 heads (I suspect stamped (not cast) with part numbers TKC 1409 and TKC 3239, respectively) are the same (on the order of 45cc per cylinder per head chamber only--not counting the deck clearance volume and piston dish volume). This and the dished pistons make a 1500 engine 7.5:1 vs. 9.0:1. If you decide to use the 75 head with the air ports, remove the little air injection tubes before you plug the holes to improve airflow.
This was posted by Paul Geithner some time ago somewhere, and I saved it for reference. Hope it helps!
