srvtribute
On the bell housing, where the clutch fork pivots, there is a pin/rod that goes through the clutch fork. My question is... should there be two retaining clips to hold the pivot rod in place? The manual shows one, and the vb catolog shows one. When I installed only one on top. the rod vibrated out again. I'm considering using a grade 8 bolt and nut instead.
