Confirmed with Nigel, (unless he's had the same replacement Triss has.) Red, translucent, plastic, not very flexible, and as far as I can tell, friction fit.
Are the threads on the fittings SAE? Or are they some funky British thread? I am in the process of replacing my clutch master and I was kicking around the idea of having a "real" hydraulic cable made up.
BTW - I will be putting a hose clamp on the bottom at the earliest convenience - Mark you're right, friction fit is a dumb idea, just hadn't thought of it before.
