'78 1500 Midget. Idiot light question. After searching this site, Teglerizer.com alternator conversion from Lucas to Chevy may well be the answer.
Condition. Engine off; battery voltage 12.5. Idle & up to 2000 plus RPM, headlights on, holds at 14.8 volts, idiot light is NOT on at all. This should be highest single item amp draw. Now turn on any single accessory; blower motor or turn signals or brake lights, voltage stays about 14.8 but idiot light comes on VERY faint (can't see in daylight). First thought, I have just exceeded alternator's ability to keep up. However, turn headlights OFF. Turn on any single accessory; blower motor or turn signals or brake lights, voltage stayes about 14.8 and idiot light again is ON very faint.
Question; how can alternator hold 14.8 V with idiot light off during heavy amp draw of headlights, yet with brake lights ONLY or turn signals ONLY idiot light is on faint? In fact, w/ turn signals ONLY, you can see idiot light pulsate w/ turn signal.
Alternator bought from local LBC parts supplier new as part number 14029N (manufacturer UNK) 3 yrs ago, 8000 miles ago. Has Lucas frame and looks like aftermarket regualator and rectifier assy. Brushes very good. Local alternator shop tested it and agrees it is regulated at about 14.8 V but will only put out 25 Amps. Sounds like a diode out, but under his heavy load, it will not activte his idiot light. He is puzzled.
We all take pride in actually fixing something, but looks like Chevy Camero alternator puts out 2 times amps at half the cost as in Teglerizer.com conversion. Car has been electrical gremlin free for 6 years. What am I missing?
Thanks.
Thanks.
Hi Guest!
