Woblynne
Member
Hi, if vac advance on the U.S cars is the same as in the U.K then there should be a small diameter pipe that links the vacuum port on the dizzy to a nipple on your front carb that faces towards the front of the car. I believe that this will aid in smooth running and also fuel economy.
Hope this helps
Mark
Hope this helps
Mark
Hi Guest!
