Gerard
Fred, check for lost travel at all the pivot points. Clevis pins can have grooves worn in them making the diameter essentially smaller (loose) and well as holes they fit becoming oval. The same goes for the fork pivot in the gearbox. Also, do you have the right cover and fork on the gearbox? There are two different ones and they sometimes get swapped by people that don't know the difference. They have different fulcrum points. You may also need to adjust the pushrod at the master cylinder. I wouldn't necessarily assume the setting you had before to be correct, especially since the clutch and gearbox are all different. There is a very limited range where it's just right. Check too that your fork is not bent. Using a too long pushrod will eventually bend the fork, giving you the problem you have. Lastly, unlike the brake side, a clutch MC does not have a residual valve, so it can be very difficult to remove all the air from the clutch circuit. There are many surefire ways to get it done, but my personal choice is to use a remote bleeder. I can provide details if you want to try that, but you need to check all the aforementioned issues first. They will have a cumulative effect on a poor performing clutch. You'll also find going to a 3/4" bore to be a significant improvement.
