Eric, you are overthinking this, trust me, I've literlly built scores of these engines and unlike most street owner in racing, we get to take them apart way more frequnetly than a street owner could ever dream about for refreshing, and we learn way more as well. Your new APT cam will come with a moly carbon based cam lube, wipe it generously on the lobes, journals, dizzy drive and the oil pump drive, and you will suffer no damage whatsoever while getting oil pressure during starter spinning. I think you would probably shocked that if for some reason, heavens forbid, you had to take your engine apart say after a few hours of operation, you would still see evidence of the assembly lube, trust me this is a non issue.
As for assembly lube else where, like the crank bearings, oil pump internals, and such, get a good assembly lube, not the runny red junk they sell at most part stores, go to a NAPA or Carquest and you will find CRC moly assembly lube, thats the stuff you want. Now on cylinder bore, 30SAE oil is all you need and don't dare dunk those pistons into bucket of oil unless you want to take forever to seat your rings, wipe the bores down with 30WT dino based motor oil,and massage a wee bit on the piston skirts, do not use snythetic oil or any sort of assembly lube on the bores and piston, or you may never seat the rings. Make sure you are using a good 1200ZDDP motor oil like Valvoline VR1 or Brad Penn.
AS far breaking the engine in on softer valve springs, that's V8 performance deal, where those guys darn near run valve spring pressures that's equal to our suspension spring rates
on these little tater bug engines, this is not a issue, the 75-85 lbs. of seated pressure and low nose pressure these engine produce, no need for break in valve springs.
Call me when you need me brother, it's all part of the package, and I'll keep you on the right path. :thumbsup:
