Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Those are pretty good I do believe. Consistency is most important.SPre engine I tested goes 125-85-100-125. Also I was told it started consuming larger amounts of oil. A Valve job is in order before it goes in to replace my 1098 in Bugsy. The 1098 gives 90 psi across the board. And it was supposedly rebuilt. Runs fairly well however and always starts on 1/2 turn of the key.
