Disassembly mode of 1275. Rod nuts seem to be a problem. 9/16 nuts. 12 point Snap-on 14 drive thin wall socket fits fine. 1/4 drive is clearly not what I want to use. Snap-on, older (better quality) S-K, and Craftsman 3/8 drive sockets simply will not even come close to fitting. Search on this web site for 1275 rod nuts turns up interesting data. There are some pictures of what I know to be called "space-saver nuts." These would be 12 point and 1/2 inch,not 9/16.
Question: has someone put the wrong nuts on these rods?
Are they supposed to be space-saver nuts?
I may be replacing bolts and nuts in overhaul. Assuming so, I can grind the old ones off. Pain in the posterior / time consuming / and I have no interest in damaging the cap.
I have used a Snap-on 3/8 to 1/4 drive adapter and enough force with a long breaker bar that I'm just short of breaking 1/4 drive lug. In fact, I'm surprised it didn't. Will not break loose.
Wrong nuts installed, and or needs a special tool. HELP.
