123 Ignition Question
Lin
For those of you using a switchable 123 distributor - not the Bluetooth programmable unit - I would like to do a little survey of which setting you have selected for your car. I have been using the “B” setting for about ten years. Curious as to what other curve settings have been selected and what the owner’s experience has been.
I really don’t want to get into a debate about the relative merits of one ignition system over another. It is a worthy discussion, but I am just interested in the response to my setting question.
Depending on how many responses I get, I may do some follow up to determine carb set-up, further timing info and etc.
Thanks!
Lin
H 123 ignition Austin Healey 2
M 123 ignition tune mapping Austin Healey 0
T 123 Ignition curve Austin Healey 5
R 123 New Dizzy [Ignition System] Austin Healey 2
A 123 Ignition vs. Mallory Austin Healey 28
Lin 123 Ignition distributor Austin Healey 4
S 123 distributor. Austin Healey 9
Tabcon Lumenition 123? Triumph 0
Jayrz 123 Electronic dristributor Spridgets 4
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
O Ignition switch / steering lock replacement in a '78 midget Spridgets 4
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Help 4
O Sprite Petronix Electronic Ignition Spridgets 10
Ripper01 TR6 Inputs regarding Simonbbc Ignition Solutions Triumph 0
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
T Ignition warning light remains on and headlights come on Austin Healey 8
L TR6 1974 Tr6 ignition switch Triumph 3
H Ignition problem or not ? Austin Healey 11
longbridgehealey Ignition light Austin Healey 11
I General TR Ignition lock barrel help Triumph 1
catfood Looking for suggestions - ignition issue Austin Healey 6
S Fried electronic ignition? Austin Healey 22
6 1965 Sprite Ignition Key Spridgets 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
Drone Dog BT7 ignition timing Austin Healey 5
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
F TR2/3/3A Ignition Timing - Again Triumph 11
S Not sure on the ignition Spridgets 12
Darwin Spitfire ignition wire gauge Triumph 2
