Tomas_Norway
What ignintion curve should be chosen on the 1-2-3 ignition?
My engine has been modified to 10:1 CR, 2" SU carbs, ported alu head and 278 deg cam. I use the same spark plugs as BJ-8 engines.
Before the modification I selected the curve most close to the original 1959 MK1 spec, and that worked fine.
But now it seems that the engine wants more advance at idle (at approx 15-18 deg@1000 rpm it runs faster/better), and that results in pinging under load.
Has anybody found an appropriate curve, and what spec is that engine?
The different curves can be found at: 123 Ignition curves
