My car is running quite well, but the pedal pressure for the clutch is more than I would like, I have been reading up on this and apparently it is a common problem on the 6 cylinder TRs, I have read of two possible solutions, one is to get the right pressure plate (original laycock I believe) the other is using a couple 11/64" drill bits to ensure the transmission is perfectly aligned with the motor so everything lines up better and slides more easily.
Has anyone tried the 11/64th drill bit trick? especially on a car that had a stiff sticky clutch? did it make a noticeable difference?
Thanks, Greg
I tend to intuitively think the pressure plate is the key, but if retightening it down with the drill bits does the trick I would gladly skip spending even more money on the car.
Thanks, Greg
Hi Guest!
