My 1098 is burning a considerable amount of oil. It barely smokes on startup, but I get a whiff of burning oil when cruising with the top down. I would estimate I'm burning a quart in about 150 miles. Odometer is broken, so I'm guessing at mileage.
Compression test on warm engine shows 170 psi on numbers one through three, and 130 psi on number four cylinder. A shot of oil in number four brought the reading to 200+ psi.
Can one bad cylinder cause this much oil consumption? Is there any solution other than a full rebuild, or any other type of test that I should do? The 130 psi reading doesn't seem that low to me, but I have no experience with these engines.
Hi Guest!
