5
57_BN4
So after a weekend running the engine I have finally achieved the 'factory' 102hp figure. The factory torque figure of 142lb at 2400 is purely dream numbers, the closest I can get is 128lbft at 3900.
The first runs I did in September last year gave about 80hp and the peak now is up to 106 so a 32% increase isn't bad.
Specs are now:
BJ8 cam grind
9.3:1 c/r
deshrouded inlet valves and de-beaked combustion chambers
lightly cleaned up ports
hardened exhaust seat inserts
K-line valve guide liners
Teflon Chevy guide seals
Total Seal gapless rings on standard pistons/sleeved bores
index ground crank with pistons coming flush with block at tdc
lightened flywheel
all rotating parts balanced
stock carbs
stock exhaust system
Joy of joys it didn't leak oil! Well ok there was a little drip from somewhere around the front pulley seal so I'll have to look into that. The gearbox synchros worked perfectly too.
This is the last five runs (right click and view image to get full size). Crankcase fuming was noticeably less towards the end so I think the rings are still settling down. Compression pressures were 135psi on all except 5 which has 130psi
vGtoqG0" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Unfortunately the BJ8 cam grind has given it a bit of an idle lope which I don't dislike but isn't quite what I was after
<embed src="https://www.youtube.com/v/N3PTRQ7y1_Q" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
So this brings the end of mechanical work save for painting the engine which is a pretty good milestone. Next task is to install the engine into the new chassis and start on panel alignment work.
Andy.
Specs are now:
BJ8 cam grind
9.3:1 c/r
lightened flywheel
stock carbs
Andy.
