356roadster
Just a short report how things are going on concerning my oil problem:
I have connected the tube exiting the side cover with a small bottle to see whether oil is coming out here -> result after 200kms: nearly zero oil in the bottle; just a few drops
Next check: I have connected the baffled vent from the tappet cover with a small bottle, too. -> result: the same, just a few oil drops on the bottom of the bottle
Next thing will be to check whether the tappet cover and the oil sump are sealed perfectly.....
I will report again.
Maybe to clarify - when removing the rocker -> the banjo bolt comes out last, when installing the rocker -> the banjo bolt goes on the rocker first before installation.
