100 spin on oil filter part number, no oil pressure after replacement
Lambdaman
Hi All
Does anyone have a part code for the filter used in the new spin on oil filters. The one supplied in the kit does not have a number.
i got what I thought was a suitable replacement at the auto shop however when the car was started, no oil pressure. Have traced it to oil entering the filter, first point on from the pump but not seems to be exiting the new filter, seems strange, any thoughts?
thanks in advance
David
andrea
K&N 2009 filter 414D3FQDGML._SS400_.jpgSPINFILTEROIL12.jpgFind this on SPIN Filter Kit instructions
Check installation by inserting a pencil in center and bottom oil holes in adapter. If
pencil goes into block, the holes are in correct alignment. If not, you have not installed
adapter correctly and your engine will not get oil. Reinstall and check hole alignment. Replace
drain plug in pan and follow manufactures instructions on spin on filter. Put in required
amount of oil and start engine. Check for leaks! Check for leaks check for leaks!
Filter to use. Wix 1516 ,NAPA Gold or replacement. Not all replacements have
the anti-drain back valve. ( To check for this valve look at the filter's small
holes, you should see a black baffle behind these hole to prevent the oil from draining out of
filter when engine is not running.
Important: check starter cable terminal so it does not short out
The Wix filter I use on both my Healeys is their number 51516 (equivalent to the Fram PH3600 I bought with the first one from Moss). A while back I bought a dozen on eBay for about $5/per; they're still available from several suppliers:
https://tinyurl.com/zacv5qh
Michael Oritt
Lambdaman--
I had a similar experience a few months back--after draining oil and changing the K&N spin-on filter I restarted and OP did not come up after at least 30 seconds of running. Several posters on the newsgroup suggested that I simply back the filter off so that the gasket was not in contact with the adaptor base so as to allow air to escape. I followed the advise and let the engine run at idle--after a few seconds oil dribbled out around the base of the filter, the gauge came up and my 10 psi OP light went out. The experience was a bit disconcerting as I have never had to do that before but in any case no damage done.
BTW stay away from Fram filters and a lot of others that have shoddy construction. Compare what you are using to a K &N or WIX and if the bottom plate is not as heavy toss it and replace.
John Turney
Lambdaman--
Stay away from the cheap Fram filters. They make four grades. Their top line filters are fine.
Michael Oritt
John--
Fram's homepage shows that they have five grades of filters and they seem to be differentiated by the filter medias but there is no mention of heavier construction for the higher grade filters. Though I have never cut a Fram apart to see the innards the baseplates on the ones I have seen are quite thin relative to a K&N.
There are a couple of oil filter studies that have been kicking around the internet for years--a google search seems to show this one as being the most current:
https://www.gmtruckcentral.com/articles/oilfilterstudy.html
John Turney
John--
I've seen several of those "studies" and videos that show the cheap Fram filters in a bad light, and deservedly so, but they're not the only one. However, the Administrator's conclusion was
IMO the winner of the best price to performance award is suprisingly a Fram.
the XG5 was one of the best in the filter test, and was only like $7-8. sure the RP and Amsoil were exceptionally good too, but they're also like $14+.
Michael Oritt
There are other brands of filters that get bad marks and Fram makes a lot of them under private labels.
I believe that the good rating was given to the Fram filter for its value in light of its cheap price as opposed to its quality alone.
ronzet Spin-On Oil adaptor for AH 100-6 and 3000 Austin Healey 9
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
