curtis
I have had an oil leak from the gearbox for sometime in my BN2 (four speed).I decided to look at it and guess that there must be a problem with the first motion shaft seal which would then manifest itself with drips through the bottom of the front gearbox casing?
However there is also a leak from the overdrive where the setting lever goes into the casing. That's the lever on the shaft with the solenoid lever on the other end.
My question is. How easy is it to replace this little seal?
Can you remove the setting lever and then access the seal. Hooking it out?
Can you slide the valve opening shaft across leaving the seal free to be extracted? If you do pull it across a little will it go back into position afterwards?
Thanks in advance.
Thanks in advance.
