Dealmaker5
https://www.ebay.com/itm/1000-LB-LOAD-LEVELER-FOR-ENGINE-CRANE-TOOLS-/350484968875Hello, Guys , I am getting ready to put my 100/6 engine in with the tranny attached , except i do not have wheels on the car nor do i have the schroud on it either. this is a very clean nut and bolt resto from bottom up and a new engine and trans rebuild. The question I have is I have moved the engine around on the 2 valve cover bolts without an issue but i am a little scared of using those same bolts to drop in the engine and tranny in one piece . I like the picture of the balancer with the chains attached to the front engine plate instead of the valve cover bolts - checking for some reasurance before I make the move . thanks
