christophe
Should i upgrade the front brakes to disc or do the drums work well when properly rebuilt and set up correctly? Are there any power assist conversion kits for the 54 with drums? What has worked best for you. My car probably has a bit more weight up front due to the V8, but i am not sure how much. Once i swap the cast iron heads and intake to aluminum, the difference might be minimal. That should shave off almost 50 pounds.
Thanks
Thanks
