Has anybody done or know of somebody that has modified or replaced the choke assembly on a 100-4? It does not work very well. For those who have not seem one, basicaly you have the cable that pulls up on a "stirup" setup that then pulls the choke levers up.
The problem is that, sometimes it will only pull up one choke lever, if any at all. So to adjust the choke you need to pull up on the choke levers (both), pull down on the choke cable, and tighten a tiny screw that holds the choke cable in place. All in a very tight spot.
There has to be a better way!!
