Bob - For the Longbridge, there is a number stamped on the right front shock tower, but it does not agree to the body # stamped on the plate on the firewall.
However this body number on the firewall plate should match the # stamped on
1 - front hood catch latch
2 - on the hood, bracket on drivers side
3 - on the trunk lid, the bracket where the prop is attached
4 - on the inside of each of the 4 pieces of the cockpit moldings
To be more specific it's the lower number stamped on the aluminum plate mounted above the "Austin" plate which has the vin number. My '57 vintage racer has the # 5636 stamped on all the areas Jim mentioned.
Bob - I forgot to note one very important item for you. It is not on the chassis, but it is on the engine. For the Longbridge, the vin # on the firewall plate of BN4L O XXXXX, will have on the engine plate of ICH XXXXX, matching.
check it out
jim
Thanks for the info. Now I am really confused. With MGs the VIN number stamped on the plate with MG (or Austin in this case) and is the same number stamped on the body-chassis. My neighbor purchased a 100-6 barn find and I thought it would be interesting to see if I could find other numbers on the beast! Thanks again for your assistance. Bob
