WaltCasten
Hello all,
My BN2 is being restored and I am trying to re-gasket the engine while it is out. One issue I have run into is the front main bearing cap stands proud of the front surface of the block by .010". The rear one was flush. FYI, this engine was rebuilt back in the late 1970s. Anyway, it appears the engine was leaking from this area so I would like to address this somehow.
Is it possible to loosen the front main cap bolts and tap this back flush? Even if possible is this a bad idea? Should I just silicone this area and be done with it? It seems like one would want a nice flat surface for the front mounting plate to be bolted to.
Any help is appreciated.
Thanks,
Walt
Thanks,
Walt
Hi Guest!
