TR6 ‘74 Tach
EWD
During cleaning the needle on my tach broke. What a bummer. Any thoughts on where to find a replacement short of buying a used tach for parts? (and then hoping to get the needle assembly off without breaking another.....)
Thanks folks,
Will
ed_h
I could not find these new. I even called a couple of repai places, but they would not sell me a used one because they needed them for repairs, and they are getting rare. Best bet is a junk tach.
Ed
EWD
EWD
Thx Ed. Yep. Finding out the same. FYI, Nisonger Instruments only rebuilds (they will sell you the gaskets) Cost for speedo and tach is $185 (each). They have the needles made to specs ($50) and this is additional if needed. The smaller instruments are $125. Turn around is ~ 2 weeks. Will further review.
titanic
Do you know if the needle for the tach is the same as the speedo? I might have a late speedo that has a usable needle.
Berry
TRopic6
Yes they are. Use care in removing it though. The plastic needle is mounted on a metal base and is very brittle from aging. It is prone to breaking at the end of the plate. Here is a shot of my broken needle; I suppose it could be glued back and carefully painted. The needle seems to have a slight curve to it, maybe creating a weak spot. P1110287.jpgP1110290.jpgP1110289.jpg
EWD
EWD
Thanks everyone. In the middle of cleaning the smaller gauges. The larger ones also need repair, blasting, and painting; so considering having them done. We'll see.
Noticed that the smaller gauges have an inside seal (looks like dried, cracked, cork) You can buy the rubber outside gaskets (and replacement small leather oil gasket), but haven't seen these gaskets for sale. Guess I could use some flexible silicone caulking.
Any thoughts?
Thx.
Will
ed_h
You can use a rope caulk product. It's less messy than caulk from a tube. I put in an amount where the bezel would squeeze out the excess, which gets trimmed off with an Exacto knife. Black is better for this, but brown was all I had at the time.
Ed
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
5 Tach Drive on Bugeye Austin Healey 10
C Tach stops when panel lights are switched on Austin Healey 5
