New E-Type Owner Seeking Advice
69S22+2
Recently purchased a 1969 Jaguar E-Type Series 2 2+2 with manual transmission and I would appreciate guidance from more experienced owners. The car was purchased via BaT and will be delivered to a British specialist shop in a few days. The planned work is new tires, transmission and diff fluid changes (all other fluids done just prior to sell) and a carb calibration. My plan is to immediately take the car from the shop on a 1500 mile roadtrip. While this may be foolish, I love to drive my classic cars, not just look at them in the garage. My question: other than the above listed work and a general inspection, what should I have the shop do prior to me driving 1500 miles? And other than tools and a AAA membership, what should I be doing to prepare for this trip? I look forward to hearing your thoughts. - Jim, Moab UT
Would be sure to check on the cooling system and fans for a start.
I bought my XK sight unseen from a"dealer". I had them put new Continentals on before they shipped it. I neglected to insist they balance and align it. 1500 miles and the fronts were shot. Your guys will know better, but check.
I have a 67 Series I roadster. In addition to what Grantura and Dale mentioned, check the alternator and battery and definitely inspect and top up the brake and clutch fluids. Make sure the master cylinder and the wheel (and clutch) cylinders are not leaking.
Thank you for sharing your story. Lesson well learned. I’ll call the shop right now!
Added to the list. Thank you very much.
Here is one. Having issues posting others (file to large). Ideas?
Yeah, just resize the image so it is less than 4MB. Lots of ways to resize images depending on your operating system. Just Google hoe to resize pictures if you're not sure.
I think it is the tyres, not the wheels.
Thanks for the help, Basil. I think I got it!
I love your idea, but I might take the car for a five and a fifty mile trip first (I guess it wouldn't have to be a there and back trip you could just start driving towards home) monitor all the gauges, especially oil pressure and coolant temp, then give it a once over for leaks etc. before proceeding.
The cars get up to operating water temp pretty quickly, but oil in the engine and the transmission and differential take longer, oil pressure can drop a lot, etc. Tool roll or cell phone and towing insurance? Just be sure to have a back up plan. I bought a $1000 Porsche 7-8 years ago and drove it home 500 miles in the middle of winter. Other than no heater it was a lot of fun. Have done with a couple modern cars too, but near as much adventure in that.
Thanks glemon. I appreciate the insight. The Jag is at a shop in Denver (six hours from my home) and the plan is for my son and I to travel to the shop in his pickup pulling an empty enclosed trailer. Assuming a short test drive goes well, I’ll attempt to drive the Jag back home. That immediate, steep 6000 foot climb from Denver up to the Eisenhower Tunnel should provide a thorough examination of the E-type’s readiness for a long trip. If she fails, we will simply load her into the trailer and return to the Denver shop.
And you haven't lived until slightly outside of Winslow AZ around midnight the points in your fuel pump failed. ;) BTW, I noticed the wheels and hubcaps in your photo. They are exactly the same as my '69 roadster. Had a "discussion" with a show judge once who claimed that no way did a that car come with those wheels.
Update for everyone. I finally picked up my Jag from the Denver shop (Sports Car Craftsmen - HIGHLY RECOMMENDED). New tires, aluminum radiator, water pump, all fluids, one carb repaired and all tuned. Drove her home to Moab - 360 miles without a single issue. Ran fantastic. Can’t get over how much torque the 4.2 engine has. All great till I got home and ripped the exhaust off backing into my high curbed driveway…
