Any idea where the fuses are located for the temp and fuel gauges?
Honestly, it’s been so long that I don’t remember. You can probably look up a solid state device that inputs 12v dc and outputs 10v dc.Where did you purchase it from?
The original thermal ones had no polarity. The solid-state ones do have a polarity. Like everything else in the car, they are connected into in the ungrounded side of the electrical supply, which is positive, since all these cars are negative ground.Anyone know whether the 1973 TR6 uses a negative or positive voltage stabilizer for the fuel gauge?
