New to me '71 Vixen 2500 and the start of many questions
escoboy
greetings all. to preface this, i have spent most of my life in British cars - repairing, restoring, racing - to earn my living w/ side trips working for the San Diego Communications Dept as well as at DEI designing car audio (spent a few years at La Jolla Audio prior) as well as building choppers and working for TORO as their field tech - fun job, i was on a golf course every day, just not playing golf 🫤 my daily driver a '72 Jensen Interceptor MkIII and stashed away on the property are 2 Jags, 2 MG's, 1 TR6, 1 BMW 630 Cs, 3 older Volvo's, 2 Toyota's - a 1st gen 4Runner and a 22RE p/u, plus other assorted cars.
i recently acquired a 1971 TVR Vixen 2500 #1982T. it has been updated (some would say bastardized) by the installation of a Chevy 327 and WC T5 5spd trans. I have yet to dig into it as the Jensen is getting a new rad, + oil/trans cooler, water pump etc so it comes first. It is looking like the 327 is possibly an L79 (350hp) but more on that l8r - my TR6 is a 1971 model so a swap would be EZ. so far, i find the cooling system badly designed so i will be fixing that promptly (i would like to drive it a small amount b4 deciding whether to pull the 327 and swap in the TR6) but I have a couple of questions:
1: this has heim jointed upper inner a-arms as well as heim jointed ends on the steering rack. i am told "not stock". they don't appear to be kludged (correct spacers on the a-arms and no extensions or oddities on the track rod ends) so i wonder were these perhaps a purchase as a "race" part maybe offered by an aftermarket supplier?
2: the brake master is a Nissan branded item (not correctly TR6) and would appear it was installed at the same time the car had its body off "restoration" as there are 3 brake lines connecting to it - 1 rear and each front having its own hard line. it appears the booster is a stock TR6 piece, however there is a ~1/2" piece of plywood between the body and the booster. is that normal? lots of brake fluid wrinkled paint on the booster and fluid below the booster on the body - so that will need resolution chopchop.
once i get it up in the air, i will report back on what i find, but i expect to find stock TR6 diff and axles 🙁
Hola Rocky! is it as windy over there as it is here?? i did see your posts on all the rear end stuff you recently machined - very nice work!
best to all,
escoboy
Would ditch the v8. Will more than likely no work well in so cal temps.
Rod ends are aftermarket. Metalastic bushings where OEM.
Yes woodspacer was factory….usually press wood.
thanks darth, poking around further i find the front uprights have ball joint uppers and lowers - no trunnions. the steering arms are part of the upright. my memory sez both TR6 and Spit had lower trunnions and separate steering arms... maybe when i pull the wheel off tomorrow, getting a closer look + caliper inspection _might_ offer up some clues...
