The 'wires in the dashpots' technique is credible, and I use it. Plus, it allows one to check airflow--and, at least indirectly, throttle position--across the range. But I do think UniSyns are a bit more accurate (maybe not enough to be worth the trouble). The canonical method for checking carb airlow is to read them separately--not very useful with the wires--then linked together.
