KVH
I have a recurring problem. See the pic of my shifter, the rattle button and spring--and that rubber spacer someone added. I just disassembled my interior for the third time on this same issue.
The button popped out and the spring appears to have caught on something and is mangled. I have extras but I'm reluctant to put this all back together and have it happen again. That will make four go-arounds. Each time, it's scary. I can barely get the car in gear.
I'm wondering if the custom sleeve added by the PO is the problem. I have extra rod stock to make my own button, but even that doesn't comfort me. The first time this happened I figured my button was the problem. I'd made it longer thinking that would solve the problem, but it didn't. Maybe I needed to make it even longer, still.
My shifter is slightly worn but I can't imagine that's the problem.
Do I dare go with no button? Will the rattling send me over the edge?
Looking back, this is such an old topic. The thought of most in the past seemed to be to try a new shift lever, but I have a spare that looks no better. I'm inclined to leave the rattle button out, and just live with it. Inside the shift rods I can feel some wear, perhaps from the button, so who knows. That may be part of the problem.
Any further ideas, I'll listen.
Hi Guest!
