...remove the thermostat. The sole purpose of a thermostat is to speed up reaching operating temp
Karl - As I recall it's a Âľ" cap with a 3/16" hole.
Maybe okay in Miami but I think Karl is in the frozen north (Canada) where an engine may need a thermostat to achieve proper operating temperature.
My car runs fine when the temp gauge is on 90 and when the temp gauge is on 160.
Is the air bleed hole abouut3/8"?I did this mod
It allows the engine to warm up better in more temperate climates. As once it’s up to temp the thermostat kicks in and regulates as normal. As has been mentioned without the sleeved bellows thermostat with the blanking parts.
I think the casting holes in the later tr4/a cars is smaller so triumph had some learning over time.
I used a 22mm plumbing end cap that the hose fits over.
Hole intentionally drilled at the top for air bleed reasons.
Does no harm.
Are you saying that plugging the bypass could cause restriction resulting in pressure that could cause leakage say on an older radiator?Hmmm. I thought it was a given that you should have an orifice in the bypass hose if you use a modern thermostat. That's how my TR4A is configured. I'd prefer to use the original type of thermostat, which shuts off the bypass when the car is warm, but they don't appear to be available any more except perhaps at outrageous prices. Yes, with the orifice you are theoretically bypassing some coolant while the engine is warm, but it's minimal--the orifice's restriction is way more than the radiator.
Well, maybe some have gotten away with it, but I still wouldn't try it. I think it's a risky practice for little benefit.
Wrong! The purpose of a thermostat is to maintain a minimum operating temperature of the engine. Your engines "cooled like a charm" because they probably never properly warmed up. A proper thermostat won't cause an engine to overheat, but a poor condition cooling system will do it all the time.Best way to improve cooling by tinkering with water flow is simply to remove the thermostat. The sole purpose of a thermostat is to speed up reaching operating temp, with a side effect of slightly to radically increasing operating temp, depending on condition of water jacket and radiator. A clean water jacket will make more efficient heat transfer to circulating water and a clean radiator will make more efficient transfer of heat from circulating water to radiator, while good air flow is needed to carry that heat out of the radiator. When you consider opinions on the operation of cooling systems, consider the law of conservation of energy. Randall Young did a good post on this years back. You can probably find it using the search feature. I ran my original TR3 in Miami, Fl. for 3 years and my current 3 in NC for 10 with no thermostat. Both cooled like a charm.
