ActionJackson
I've purchased a new Column lock with new key set, Original keys have been MIA for at least a decade. Anyway, I went to install the new switch today, Only to find out they are different. I've only seen one switch listing for everything FM60,006 and older, Mine is FM74000+. What needs to be done with the green wire that attached to the terminal on the old switch? Does this need to be grounded?
Hi Guest!
