Hi I am new to the forum, I have a problem with a 1275 1973 midget I aquired, it has continuos blue smoke coming from exhaust when warm, I have checked the usual breasthercase pipe and proceeded to take the head off and investigate but it looks a good engine rebuild but the gasket was blowing between 2 and 3 cylinders , I suspect it is a ring issue maybe stuck or broke, maybe he didnt bed it in properly and retighten, anyways my first question is I have taken all sump bolts out but she wont budge as I want to remove the pistons for inspection, have I missed something else or does it just need a good pry, maybe the timing cover bolts need slacking , hope not, this is my first midget, my other 2 are jags which I am much more familiar with, there is a story behind this one as there usually is with it being overfilled with oil as the oil filler tube had been incorrect;y installed, prior to this overfilling there was no issue with the engine smoking, at first I thought it would just burn off as oil was going into the exhaust which leads me to believe it is rings.
Thanks in advance for any help with this one.
Hi Guest!
