Frank Canale
I decided to take a look at the rear leaf springs as I am starting to paint chassis parts. The springs look a little worse than I had remembered. I did a quick test to see if they were close to spec. I weigh about 140# so I set up a block under the spring with a 1 “ space and stood on the spring and both springs just barely touch the block. The spring will push me off the block so I think they are still ok spring wise. I would like to know thoughts on taking them apart to clean them and paint. Is anybody lubricating their springs. Plenty of info online but curious what TR3 owners are doing, real world experience. Frank
Hi Guest!
