Results 1 to 19 of 19
Thread: I think generally this flood might have been good(ish)
The Pub is: Forum to generally shoot the breeze. It is NOT: a debate forum (NO Politics, religion, or controversial topics.) Keep it clean, fun and lite!
  1. #1
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,767
    Thanks Thanks Given
    Thanks Thanks Received
    60
    Thanked in
    A curious combination of events this morning.
    1. went downstairs and found half the basement flooded.
    2. But it was clean water.
    3. With some research (and mopping up) realized that it was from the humidifier on the furnace. It drains into the floor drain, but, the floor drain was full of water (hmmm?) so there was no place to go but up. literally.
    4. So, a little more research revealed that there was a blockage (not quite 100%) in the drain pipe from the stack on the north side of the house to the one on the south side. which meant the house bathrooms were fine but not the apartment or the laundry.
    5. Ended up renting a very cool 50' snake from Home Depot - automatic feed - amazing! and managed to blow out the clog.
    6. In the midst of this discovered the anti backflow unit in the aforementioned drain didn't work so dirty water could flow out of the drain into the basement. Replaced it as well.
    so, to recap. Yes I had a flood but it was clean water and in cleaning up I managed to clear a clog which could have caused a dirty water or even sewer water into the basement which would have been so very much worse.
    Oh and the whole thing - rental, new valve etc etc was less than $100. Not sure I could have found a plumber who would have pulled into my driveway for less than $100.
    So yes, a nuisance but could have been so much worse and the added bonus was that I pitched a bunch of 1/2 bags of grout and other cr*p that should have gone years ago but now that it was wet....
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  2. #2
    Administrator Basil's Avatar
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    24,221
    Blog Entries
    7
    Thanks Thanks Given
    63
    104
    Thanked in
    Re: I think generally this flood might have been good(ish)
    Glad you were able to troubleshoot and fix it yourself. Always feels good to save lots of money!
    The smallest act of kindness is worth more than the grandest intention. - Oscar Wilde
  3. #3
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,274
    Thanks Thanks Given
    21
    Thanked in
    New Year's Day putting tables back found a big puddle under the high efficiency furnace. Hot water tank next to it. Hot water tank dry.
    Figured major issue, prepared to pull it apart to inspect heat exchanger....first order of business was to pull the water trap. Quick grab a bucket to catch over a quart of water.
    Trap plugged. Flushed it out and almost three weeks later still fine.
    Scary
  4. #4
    Darth Vader Bayless's Avatar
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,572
    Thanks Thanks Given
    14
    Thanked in
    I hate plumbing!
    Was Man nicht im Kopf hat muss Man in den Beinen haben
    '48 Ford Prefect
    '67 Sprite (project)
    '74 Super Beetle
    http://enfoprefect.org
  5. #5
    Join Date
    Sep 2012
    Location
    Pickerington OH
    Posts
    399
    Thanks Thanks Given
    3
    Thanked in
    I do too, Bayless. It either goes really bad or fairly good. Going to ruin a perfectly good day soon replacing batroom lav faucet. Hoping the shut-offs work!
  6. #6
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,803
    Thanks Thanks Given
    13
    45
    Thanked in
    The plumbing fittings in the US seem to not have a standard so it is difficult to mix manufacturers products. Also Shower mixing valves and mixing taps seem to change on a regular basis with no thought to spare parts for last years model.
    Maybe a slight exaggeration but it does seem that way at times.
    Not too fond of plumbing repairs myself.
    David
    TR3A TS75524L
  7. #7
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,309
    Blog Entries
    1
    Thanks Thanks Given
    61
    108
    Thanked in
    Quote Originally Posted by 65_BRG_Sprite View Post
    Hope you have better luck than I usually do. Turn the shut-off valve - valve cracks or pipe joint leaks. Replace what's needed, and follow the detailed instructions "Tighten until sealed, but not too much."
    For me, electricity is either *on* or *off*. With plumbing, it's either *leaking* or *about to leak*.
    OK - back to enjoying our major ice storm.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  8. #8
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,110
    Thanks Thanks Given
    33
    67
    Thanked in
    Quote Originally Posted by Bayless
    I hate plumbing!
    Same here.
    Been lucky here so far, the only plumbing issues have been self-induced. Sooner or later I know the in-slab copper is going to be a problem, though.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  9. #9
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,767
    Thanks Thanks Given
    60
    Thanked in
    Quote Originally Posted by DrEntropy View Post
    [/COLOR]Same here.
    when we lived in Florida I had a damp spot on the wall. Mrs JP says "fix that so I can paint." 10 minutes later 2X2' square of drywall is missing. Grumbled about it at church and parishioner says "I think there is a class action suit about that." Sure enough - some problems with the joints - don't remember the details except that they replaced it for free. Installers had been at this full time for 8 years and figured they had 12 more years to do.
    At that time I also learned that copper is affected by lightning strikes and gradually develops pinholes - Orlando being the lightning strike capital of (at least) the USA we went with Pex.
    It is currently 2 deg F here in Toronto and projected to get colder. The pipes going into the apartment are exposed in the garage and I have them insulated and heated but part of me is sitting here wishing I had gone with pex not copper with them as well.
    John-Peter Smit
    1976 MG Midget
  10. #10
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,110
    Thanks Thanks Given
    33
    67
    Thanked in
    My sympathies, JP. When we lived up north, sub-zero (F) temps were always a concern. Had exposed copper in some small unheated areas with a run to the detached garage. Had to insulate and heat those with a 100W light bulb! The next summer we built enclosures and fixed the problem.
    I got really good at sweating copper joints as a kid, now plumbing is like playing with Legos... with some shears and glue added.
  11. #11
    Yoda PAUL161's Avatar
    Join Date
    Jan 2005
    Location
    Locust Grove, Oklahoma
    Posts
    9,464
    Thanks Thanks Given
    1
    44
    Thanked in
    When we had this house built we went with Pex, even though I've never had a problem with copper. Water can freeze in Pex and all it does is swell up a bit when it thaws it returns to its original size, or so I've been told. A lot of older homes have type M copper pipe which has thinner walls than type L and there lies the problem on durability over the years, type L is thicker, will take more pressure and will last much longer. Many local codes have been upgraded making type M illegal in new homes. Also, back in the day, a lot of contractors started using aluminum wire in new homes because it was much cheaper with no restrictions on it's use, but because electrolysis affects aluminum connections over the years and can become a fire hazard most local codes have been changed making copper wiring the only option. Heavy aluminum can still be used from the street up to the main breaker as it is thick cable and the bugs used for the connections grip and squeeze the wires very tight. PJ
    Remember, Never Forget
    We Live In The Land of The Free
    Because of The Brave
    How good it feels, the hand of an old friend! Longfellow
  12. #12
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,912
    Thanks Thanks Given
    16
    49
    Thanked in
    [/COLOR]Same here.
    The builder of the homes in the neighborhood where we bought our first house installed in-slab copper covered by linoleum. This was done in the mid '60s and by the time we moved into the neighborhood in the late 70s it was common to hear jackhammers opening floors to chase leaks. Lots of folks just installed baseboard electric, but the cost of electric heat in New England was outrageous. Good luck, Doc.
    Rick
  13. #13
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,753
    Thanks Thanks Given
    51
    34
    Thanked in
    Copper here, but the POs used galvanized nipples to the shut-off valves in the walls.
    John, BN4
  14. #14
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,767
    Thanks Thanks Given
    60
    Thanked in
    Quote Originally Posted by HealeyRick View Post
    Was at a church yesterday for their anniversary (I pastored there in the 90's) the whole place has electric heat because 9 months before they built the church in 1984, another church burned down because of a gas leak - so the building committee decided to be "smart" and go for electric heat - don't even want to speculate how much more they have spent over these past years.
    John-Peter Smit
    1976 MG Midget
  15. #15
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,767
    Thanks Thanks Given
    60
    Thanked in
    Quote Originally Posted by John Turney View Post
    we got rid of the last of the galvanized (about 3 feet) with the last bathroom reno. I have one 7 foot run of copper drain that I will replace with ABS when we do the kitchen which will leave about a foot of lead under the toilet in the apartment - and that can stay!
    John-Peter Smit
    1976 MG Midget
  16. #16
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,572
    Thanks Thanks Given
    14
    Thanked in
    My house was built in'55 with copper under the slab. But all the nipples were galvanized. That saved maybe $5 on the cost of the plumbing? I replaced them with brass.
    '48 Ford Prefect
    '74 Super Beetle
  17. #17
    Join Date
    May 2007
    Location
    Chicago, IL
    Posts
    4,783
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by JPSmit View Post
    Would it be accurate to guess it was the bottom half? I did read the rest of the thread and saw that all turned out for the better.
    Peter Hays, Chicago, Il
    1959 Morris Minor Convertible - "Truly Scrumptious"
    1959 Morris Minor Traveller - "Sammie"
    1963 Mini MkI Traveller = "Little Red"
    1956 Jaguar MkI 2.4
  18. #18
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,767
    Thanks Thanks Given
    60
    Thanked in
    Quote Originally Posted by Silverghost View Post
    No! the southern half ;p
    John-Peter Smit
    1976 MG Midget
  19. #19
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,345
    Thanks Thanks Given
    22
    Thanked in
    Here on the west coast of Florida, you have to make sure the house has been "re-piped". Apparenlt the water here eats out the pipes or something. That's why I rent, not buy.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
