Re: Worrisome compression test results on my MGB 1
Ok, I took the drive. It's about 20 miles each way, and that's all I had time for in between class. I didn't feel comfortable going much more than 70, so I would drive the speed limit for a bit, then gas it up to 70 really fast. I'd hold it there, then let it go back down, cruise for a bit, then get on the gas again. It pulls, and sounds growly and rumbly while doing so.
At the turnaround point, I stopped for gas and lifted the hood. There is definite seepage on the non-manifold side of the head in the gasket area. I've read that can be normal, but it seems odd. Is that a clue that the head gasket is bad?
If I pull the head, would I be able to look down at the cylinders and see visible trouble? I may call the rebuilder and see what they say as well. I don't mind pulling the head, but I remember changing the manifold gasket earlier in the year, and getting the exhaust to move out of the way was a real PITA.
As far as the oil goes, what I remember them telling me was that they put dino juice in it first, and that I should drain that at 1500 miles. Then, refill with 10w40 dino and drain again at 1500. After that, use 10w40 full synth and change every 2500 miles. They didn't require the synth, just recommended it. Should I use some 20w50 dino juice next oil change?
No matter what might be the trouble, it's irritating to think that something I did probably caused it. I'm not trying to avoid the blame, but learning the hard way is the worst thing.
