Wolseley 6/110==>>Healey 3000/6
healeysa
Can anybody advise me please
1) Is the wolseley 6/110 chassis the same as the healey 3000/6?
2) How much of the wolseley can be used to build a healey
3) Where could I find a healey chassis if the wolseley one can not be used?
Is this kind of project feasible or have I lost it!!
Many Thanks
Bob
The Wolseley wheelbase is shown as 9 ft 2 in ~2794 mm while the Healey's is shown as 2330mm. That alone would seem to make a swap an exceedingly dubious prospect.
I wouldn't be surprized if odd mechanical or trim bits might fit, but I do not think any major body components would. But it too used the BMC "C" series engine along with the Healey so engine and gearboxes might be compatible... but I'd want to look at what was there and see things side-by-side to be sure.
If you need a new chassis there are several suppliers in the UK and USA that make them- Jule is one, in Canada; the UK Healey Centre, Cape International, Denis Welch and AH Spares in the UK. You seem to be in South Africa and I am unaware of any there.
I'd suggest you join a local club and see what they can tell you....
bob hughes
Engine and transmission would be ok, but the head would not be standard Healey. Some rework required there, the cam would probably need altering too. Overdrive switch, speedo and rev counter probably the same, along with any other guages. Window winder possibly the same as a BJ7 / 8, not sure about the back axle.
Bob
5
57_BN4
6/110 uses Borg Warner R11 OD which is much more fiddly to drive as there is no engine braking below 30mph. My Ford has one.
I think the Wolley used the same front suspension as the Healey too.
Andy.
H
healeysa
Many thanks to all for the info looks like I salvage what I can and discard the rest. Anybody know of a secondhand chassis?
Andy many thanks for the download
Kindest
Bob
saltiga
Austin A99 & A110 have many parts that are useable. Engine bottom end parts, the head is totally different, exhaust & inlet valves are smaller in dia. the rocker gear is the same, the gearbox housing is the same on the A99 not sure of the A110, the gears & syncro are different, the diff centre is the same but check the ratio to make sure, housing is wider as with the axles, the door handles, window winders are the same, the window mechanism looks the same but they slightly different, I think the wiper motor housing is the same, but the elect. motor is 2 speed. some of the electricals are the same. the chassis is totaly different, none usable, as with the brakes, a totoly different brand. Do as I did conpare components . Many nuts & bolts are the same. Best of luck Trevor S.
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
aeronca65t Wolseley 107 years old Other British Cars 1
Mickey Richaud Wolseley on eBay Other British Cars 1
G Wolseley 6/90 on ebay Other British Cars 5
aeronca65t Nice Wolseley Other British Cars 0
Wray New Wolseley guy? Other British Cars 4
Kira A Great Wolseley Man: Peter Richardson Other British Cars 7
Sherlock 1957 Wolseley [in CA] - emergency rescue Other British Cars 5
D Wolseley 6/99, /100's Other British Cars 2
Bruce Bowker 1938 Wolseley Other British Cars 6
Sherlock Neat Wolseley find, 1934 Hornet Special Other British Cars 1
Sherlock Wolseley 1000 British Motor Corp 8
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 8
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
