Wiring connections for electronic ignition BJ8?
SteveHall64Healey
Gents, I'm trying to install a Petronix Ignitor on my BJ8 25D distributor with POSITIVE ground.
The wiring instructions are not that clear. Can anyone confirm how the leads are to be connected?
thanks,
Steve
Installing a pos. grnd. Pertronix ('P') is simpler than neg. grnd.: https://www.pertronix.com/support/manuals/pdf/ignitor12vpos.pdf
The black lead on the P needs to be spliced to your ignition switch wire. I don't remember what color the ignition switch wire is--IIRC, it's white, but not sure--but with points it should have gone to the '-' or 'SW' terminal on the coil. The black/white lead from the P now goes to the '-' or 'SW' terminal on the coil. The '+'--this may be labelled 'CB'--terminal on the coil now needs a wire to chassis ground; I used the white/black wire that goes to the battery cutoff switch. This will retain the 'anti-theft' capability of the cutoff switch, but the terminal from the b/w wire will need to be moved to the large terminal on the cutoff switch that (also) switches the battery to ground. Otherwise, you can just run a wire from the '+' terminal on the coil to somewhere on the engine or chassis that is well-grounded.
Timing will change significantly, but you should be able to start the engine after the P install, then re-time it. If you want to carry points as backup, use M/F spade lug connections instead of butt splices. Don't leave the ignition switch on without the engine running any longer than necessary; this will fry the Pertronix.
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
F Spitfire 78 Spit solenoid wiring connections Triumph 2
A Wiring connections for starter solenoid Spridgets 1
startech47 CEI distributor wiring connections?? Spridgets 2
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
