Wiring an electric tach in a Bugeye
G
I am attempting to replace my mechanical tachometer with an APT electric tach. Can anyone tell me which connections must be made? On a negative ground 1275 with alternator, does the tach get wired into the positive or negative side of the coil? Is there any wire that goes to the alternator?
Tim C.
ThomP
Tim
On a modern tach there should be four wires:
Ground, perhaps the case, perhaps a green or black wire. This should go to the chassis of your negative ground car
Power or +12, perhaps red. This should go to any convenient switched power source. Switched sources are often white or green wires in the bugeye. Green are fused, white are not fused
Sense, who knows what color. This should go to the "Points" side of the coil. If your coil was properly reversed when the electrical system was changed, this will be the negative side of the coil.
Lighting, again who knows what color, but is the power for the light inside the tach. If you can find a red wire with a white tracer or band on the bugeye attach the light wire there and the tach will light when you turn on the dash lights.
Disclaimer: I have never seen your bugeye, please verify your wiring matches my suggestions.
Cheers, good luck
G
ThomP,
Thanks for the reply. I believe I have everything wired up as you indicated, and do still have the original wiring harness so the wire colors are as you indicated. I'll fire it up this weekend and see if I can keep the smoke in the wires this time! As for your disclaimer, I'm attaching the URL where a photo or two of my car is seen. It's a little hard to miss at the shows I go to!
creger.html
Hi Tim,
i dont suppose you work for Gateway?... own a farm..?
Nice car
mark
ThomP
Kinda hard to miss that car! After seeing the paint, I'd check the driver/restorer and forget the wiring harness!
G
I connected and test fired the new tach this weekend, looks like everything works, and NO SMOKE! Thanks for the help from fellow listers.
Tim C.
R Electric fuel pump wiring Spridgets 4
GTP1960 TR2/3/3A Electric fan wiring Triumph 11
M TR4/4A TR4A Electric fan wiring ? Triumph 2
G Wiring an Electric Fan Triumph 23
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Sopwith_Camel MGB wiring new Tacho MG 0
