Wiper set up help needed
Don Jarr
Member
Hi
I’m after a bit of information, regarding what classic cars use the same windscreen wheel boxes and cable that a mini does. The cable pulls and pushes to operate the wipers.
I’m actually trying to find out if any other cars use a longer length of the spiral cable, as I have built a custom car, and the wipers go in and out, opposes to side to side, and I could really do with a longer length. The Mini length works, but it really would be better if it was about 6 inches longer.
So if any one knows any other car that uses this type of wiper set up, I would be really grateful if you could let me know, so I can find out what length they use.
Thanks
Don
D Wiper set up help needed Sunbeam (Rootes) 3
D Wiper set up help needed Lotus 1
D wiper set up help needed Jaguar 2
J Need wiper set up for race car Racing 3
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
R TR2/3/3A TR3 Wiper motor Triumph 10
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
R TR2/3/3A Wiper Arms Triumph 8
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
R TR2/3/3A Windshield Wiper System Triumph 2
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
M TR6 Wiper washer knob Triumph 5
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
P Wiper direction Austin Healey 9
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
J TR2/3/3A Wiper Motor bracket Triumph 5
JPSmit Question - wiper switch and signal switch ends Spridgets 4
T TR5/TR250 TR250 wiper switch and motor Triumph 1
JFS TR2/3/3A Wiper Cable Lube Triumph 5
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
sparkydave Wiper switch repair Spridgets 5
F TR2/3/3A Beware eBay wiper blade and arm sales Triumph 6
