Windshield reassembly in a BE?
TexasSprite
Before I start experimenting with how much stress 50 year old glass can take before breaking, does anyone have any suggestions on how to assemble the frame/glass/gasket combination? I'm guessing you seat the glass in the gasket then into the bottom of the frame and then work the lip over the glass as you work your way toward the top of the frame. There did not appear to be any sealant on the glass when it was removed, but everything was fossilized, so it was hard to tell.
jlaird
No sealant. Use lots and lots of dish soap.
TexasSprite
TexasSprite
Not having much luck here despite liberal amounts of soap. Are you supposed to put the seal on the glass and try and work them into the frame or are you supposed to put the seal into the frame and work the glass into the seal?
jlaird
Darn if I know. Stand by for someone who has done this.
spritenut
Seal on the glass and it has to be roped into the frame, it's not a push it in with your hands type of set up.
Using a thin rope between the seal and frame, pull the rope around the frame and the glass pops right in.
At least it does for the guy at my local glass shop. He has showed me this many times, my son can do it, I can not.
TexasSprite
TexasSprite
Update on progress:
I did get the seal installed in the windshield frame the hard way by squeezing it in with my hands and judicious use of a screwdriver as a prying bar. It was not easy and took a long time. I had thought about using the rope idea, but only for getting the glass into the already installed seal. One of the other forum members had done it that way and had as much problems as I did. Moral of the story: try spritenut's tip next time!
jlaird
You know the wedges used to install windows and doors in homes. They are now made in plastic and are great for not maring things that screwdrivers do.
Glen_B
I made extensive use of plastic bicycle tire levers and dish soap. As per Frank, glass into gasket, both into frame with liberal application of profanity.
Glen
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
steveg Rebuilding roadster windshield Austin Healey 24
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
Z TR2/3/3A Windshield Aftermarket Triumph 22
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
D TR2/3/3A Windshield difficulties Triumph 24
Rut Cut down windshield Spridgets 22
R Windshield Washer Pump Repair Austin Healey 9
M BJ8 Windshield Austin Healey 10
G For Sale Morgan Folding Windshield Posts, Original 1960s-70s “Small Quadrant” Style, $600 Other British Classifieds 0
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
Rut Windshield rubber seal Spridgets 6
C Removal of windshield posts from my 100-6 Austin Healey 7
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
P Rivets on windshield and vent window frame. Austin Healey 1
DrEntropy E-Type windshield FYI: Jaguar 1
JPSmit Windshield and Wheeler Dealers Restoration & Tools 11
R TR2/3/3A Putting windshield back together Triumph 13
D TR5/TR250 Windshield wiper motor Triumph 9
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
Joe Schlosser BE windshield screws Spridgets 4
