upgrade to electric cooling fan?
recordsj
1500 mg midget engine.
I am considering upgrading to the electric engine cooling fan. Any issue/reasons not to?
Any experience with these positive or negative?
R
recordsj
the fan clutch (it had an oily substance coming out of its seal) needs to be replaced. I noticed it is a bit cheaper to get a electric cooling fan instead of a new fan clutch.
sqbsprite
I bought a 10" Hayden at Advance Auto for $55. It did not include a temperature sensor so I just wired it into a switch. I only use it when needed. It was much less expensive than some other kits and it works great. I mounted it as a pusher on front of the radiator. I had to remove the radiator to install it because it would not fit through the grill opening. I have not removed my plastic engine fan yet. I have a 1275 which did not use a clutch on the fan. I'm not sure on the later radiators, but you may have room to install it behind the radiator once you remove the old fan. Just make sure you verify which way the air flows. You can reverse it by flipping the fan over on the shaft.
bugedd
I had been thinking about that as well on my bugeye. It seems the drilled temp. senor on the radiator would be a good place to put a sensor for a fan. The one of the gauge is in the head, a better place for that. Anyone have any experience with this?
R
recordsj
I asked this same question. With the fan from Moss, it includes a sensor that goes into the radiator fins which turns the fan on/off.
That is how I have mine. Seems to work fine. Going on three years now.
bigjones
On my 1500, I bought a slim fan off Ebay but it would not fit behind the radiator (even if I had hack-sawed off that bit of the water pump shaft that holds the fan clutch).
What I'm trying to say is that whatever fan you buy it will have to be mounted in front of the radiator.
No big deal of course.
Cheers!
Pythias
I want to have a look at that in Wisconsin... See ya there.
R
recordsj
With the Moss kit, it includes a sensor that goes into the blades of the radiator. Has anybody tried the kit from Moss and can say how well it works or not?
Sarastro
You can buy a large, 12-volt fan from any electronics catalog--take a look at Digi-Key for example (https://www.digikey.com/). I made an electronic controller, (https://www.nonlintec.com/sprite/controller/) and I think it's come on maybe twice in its life--but I didn't remove the engine fan. The idea was to have something to prevent overheating in traffic on hot days. If you are removing the engine fan, though, you obviously need a thermostat, Probably can get one from any of several places, like maybe Summit Racing.
Moss just buys the parts off the shelf, puts them in a box with instructions, and charges twice what it would cost you to do the same thing.
Jim_Gruber
Other alternative is using a Geo Metro Radiator like Frank did for PIECES. There are pics over on SpriteSpot.com page under Cooling Section. I am planning on one of these conversions for Bugsy my '68 with BE Bonnet. Temps rise on long 65+ expressway speeds although around town perfectly adequate. This conversion close to doubles cooling capacity plus adds an electric fan. See article for more details.
R
recordsj
I couldn't find the article or pictures you are talking about on that website. Do you have a link for them that you can post?
nomad
You know, I've looked at the Geo metro rad in junk yard cars and that thing is tiny. Where do the specs that say it will cool that much better come from? I have a hard time believeing them though it sure would fit easily enough.
Just needing a little reassurance!!
Kurt.
Jim_Gruber
Look under Cooling Section, Modern smaller radiator for your A series Spridget
Pics and article are there.
Per Frank C. he has no more high speed cooling issues andy more since switched to Geo Metro Radiator. They are also available as 2 row units.
nomad
Read up on Franks setup and suppose I was looking at the 2 row rad. Guess its definetly worth a try. If it works for Frank it'll work!
Kurt.
Jim_Gruber
Note that there are two radiators, you want to use the Auto Tranny I think, I need to go back and reread the notes as one of the radiators is 1 1/2" shorter than the other. My thought was if bought new, could you use the tranny cooler section as an oil cooler and ditch the 13 row external oil cooler I have sitting in front of the radiator. Hmmm
Jim_Gruber
I know when I looked for Radiators for Geo Metro new replacement for OEM rather than go junkyard, they show a total height on just over 14" and spec out as double row or even triple row someone told me. They and the Hayden electrci fan and Bob's Your Uncle.
abarth69 Innocenti 1275 upgrade path Spridgets 1
S fuel pump upgrade Spridgets 0
P Suspension upgrade for a A40 Devon. British Motor Corp 0
S Sprite Fuel Pump Upgrade Austin Healey 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
petnatcar Fuel Line Upgrade Austin Healey 8
petnatcar Fuel Pump Upgrade Austin Healey 2
B 948cc Engine Upgrade Austin Healey 2
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
Guido36 LED Headlight Upgrade Austin Healey 1
M Tachometer not working following ignition upgrade Austin Healey 10
Lin New Forum Upgrade Question Austin Healey 8
M TR6 Alloy Wheel Upgrade Triumph 19
J General TR Cam shaft upgrade????? Triumph 3
roscoe 100 harmonic balancer upgrade? Austin Healey 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
Got_All_4 TR6 Heater upgrade Triumph 6
S TR4/4A Coil-over suspension upgrade Triumph 4
B Windscreen washer pump upgrade Austin Healey 10
Marvin Gruber 100/6 Brake Upgrade Austin Healey 5
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Keoke Latest Upgrade Austin Healey 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
V BJ8 Tacho upgrade Austin Healey 9
T What is needed for a 'big brake' upgrade; how well does it work? Spridgets 14
B Radiator upgrade Austin Healey 55
S LED Exterior Light Upgrade Spridgets 15
Rut TR4/4A Frame upgrade Triumph 2
TomMull General Tech Headlight upgrade Triumph 9
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
HealeyRick Brake Caliper Upgrade Austin Healey 120
O 57 100-6 Disk Brake Upgrade kit Austin Healey 9
S austin a40 somerset chassis swap/upgrade Restoration & Tools 2
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
RJS TR4/4A R200 Differential Upgrade Triumph 2
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
D Bumper Bracket Upgrade Spridgets 6
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
Michael Oritt Engine upgrade Racing 8
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
J Upgrade to blasting cabinet Restoration & Tools 7
C Wedge TR8 Radiator upgrade Triumph 13
bobh TR6 TR6 Brake Upgrade Triumph 19
B seat belt upgrade complate ! MG 1
TonyPanchot Spitfire Carb Upgrade Spitfire Triumph 4
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
DanLewis Bugeye rear brake upgrade - hubs now rubbing Spridgets 3
A XKE Series II Stromberg Carb Upgrade Jaguar 4
