Rain let up. Having a real outing with the car finally. Only took a decade. Let’s see if I can make it back despite my husband potentially jinxing me with the generator and fuel pump comment.
Antique machine does not have cup holders, but I found something that works just as well.
Next thing on the to do list is getting the heater and fuel gauge to work, because without it, I can’t really go that far. Unlike the speedometer, there’s not an app for that. ...at least, not for the Triumph. The fuel gauge never worked, as the float was stuck and corroded. That’s been replaced, but still doesn’t appear to work. The temperature gauge always worked, but has not since the rewiring kit I installed
Update: Stranded at Sonic. I foolishly left home without starter fluid, but thankfully there’s a Kwik Kar chain right next door that let me borrow theirs. I took the air box off and sprayed, something I am now quite experienced with. Only it didn’t catch. It usually cranks up, runs, the dies once it’s used up the fluid. It’s not doing that. It’s got air (removed airbox, choke open). It’s got fuel (starter fluid). All I can figure is it’s lacking spark. Richter12x2 is on his way, after picking up what will be it’s 3rd coil.
